Ir para o conteúdo principal
  1. Shut down the laptop and disconnect the power cord.
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Remove six 10 mm T7 screws. Remove four 6 mm T7 screws. Use the blue plastic opening tool to carefully remove the rubber pad which covers the two remaining screws.
    • Remove six 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove the rubber pad which covers the two remaining screws.
    • Remove the remaining two 10 mm T7 screws.
  3. Carefully lift the cover upwards.
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
Conclusão
F Fernandez
Membro desde: 13/01/2015
420 Reputação
2 Guias de autoria
Equipe
USF Tampa, Team 3-4, Hickman Winter 2015 Membro de USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Membros
7 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 92
