Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Changing the Battery in an Acer Aspire R7 is a straightforward process if you find your computer has lost its ability to hold a charge.
The Aspire laptop battery enables the computer to work without having a power cord. It is a hardware component that is not externally accessible and requires a small amount of disassembly to replace.
The 4-cell replacement battery instructions are listed below in quick simple steps. Before using this guide make sure that the battery can no longer function in one of two ways, use a multimeter to test battery strength or check the settings on the laptop if possible.
If the battery is swollen be careful and proceed with caution and take appropriate precautions.
O que você precisa
Locate the battery ribbon connector
Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
12 outras pessoas executaram este guia.
6 comentários
great instructions
hey how do you want då sel it for
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
