Acer Aspire R7 Battery Replacement
  1. Acer Aspire R7 Battery Replacement, Cover: step 1, image 1 of 1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Battery Replacement: step 2, image 1 of 3 Acer Aspire R7 Battery Replacement: step 2, image 2 of 3 Acer Aspire R7 Battery Replacement: step 2, image 3 of 3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 Battery Replacement: step 3, image 1 of 1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Battery Replacement, Battery: step 4, image 1 of 2 Acer Aspire R7 Battery Replacement, Battery: step 4, image 2 of 2
    • Locate the battery ribbon connector
    • Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
    • When using the spudger be careful around the motherboard as it can easily be damaged
  5. Acer Aspire R7 Battery Replacement: step 5, image 1 of 3 Acer Aspire R7 Battery Replacement: step 5, image 2 of 3 Acer Aspire R7 Battery Replacement: step 5, image 3 of 3
    • Remove the three 4.5mm #00 Phillips screws attaching the battery to the motherboard
    • Push the 4 retaining clips away from the battery
    • Carefully lift the battery from the motherboard
F Fernandez
435 Reputation
2 Guides authored
USF Tampa, Team 3-4, Hickman Winter 2015 Member of USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 40
All Time: 41,154
