Ir para o conteúdo principal
Introdução
The 4-cell battery on the Aspire R7 is not externally accessible and requires a small amount of disassembly in order to replace it.
  1. Shut down the laptop and disconnect the power cord.
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
    Use the blue plastic opening tool to carefully remove the rubber pad which covers the one remaining screw.
    Picture shows the rubber pad removed but srew to be removed is not indicated
    Anthymoine - Responder
  2. Remove six 10 mm T7 screws. Remove four 6 mm T7 screws. Use the blue plastic opening tool to carefully remove the rubber pad which covers the two remaining screws.
    • Remove six 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove the rubber pad which covers the two remaining screws.
    • Remove the remaining two 10 mm T7 screws.
    Step 2 is missing the 1 (10mm T-7 ) screw that is under a rubber pad in the bottom middle of the laptop. The picture shows this pad and screw already missing. Note the silver color instead of the black color of the rest of the bottom of the laptop.
    Daniel Flynn - Responder
  3. Carefully lift the cover upwards.
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Locate the battery ribbon connector Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
    • Locate the battery ribbon connector
    • Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
    • When using the spudger be careful around the motherboard as it can easily be damaged
  5. Remove the three 4.5mm #00 Phillips screws attaching the battery to the motherboard Push the 4 retaining clips away from the battery Carefully lift the battery from the motherboard
    • Remove the three 4.5mm #00 Phillips screws attaching the battery to the motherboard
    • Push the 4 retaining clips away from the battery
    • Carefully lift the battery from the motherboard
Conclusão
11 outras pessoas concluíram este guia.
F Fernandez
Membro desde: 13/01/2015
420 Reputação
2 Guias de autoria
Equipe
USF Tampa, Team 3-4, Hickman Winter 2015 Membro de USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Membros
7 Guias de autoria
great instructions
amaryheart7777777 - Responder
What is the battery reference for replacement ?
skalpinou - Responder
which battery model do I purchase for replacing on an Acer Aspire R?
Eddie - Responder
hey how do you want då sel it for
Alex santos - Responder
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 61
Últimos 30 dias: 258
Duração total: 37,462
