Ir para o conteúdo principal
Acer Aspire R7 Battery Replacement
O que você precisa
  1. Acer Aspire R7 Battery Replacement, Cover: passo 1, imagem 1 %32
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Battery Replacement: passo 2, imagem 1 %32 Acer Aspire R7 Battery Replacement: passo 2, imagem 2 %32 Acer Aspire R7 Battery Replacement: passo 2, imagem 3 %32
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 Battery Replacement: passo 3, imagem 1 %32
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Battery Replacement, Battery: passo 4, imagem 1 %32 Acer Aspire R7 Battery Replacement, Battery: passo 4, imagem 2 %32
    • Locate the battery ribbon connector
    • Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
    • When using the spudger be careful around the motherboard as it can easily be damaged
  5. Acer Aspire R7 Battery Replacement: passo 5, imagem 1 %32 Acer Aspire R7 Battery Replacement: passo 5, imagem 2 %32 Acer Aspire R7 Battery Replacement: passo 5, imagem 3 %32
    • Remove the three 4.5mm #00 Phillips screws attaching the battery to the motherboard
    • Push the 4 retaining clips away from the battery
    • Carefully lift the battery from the motherboard
Conclusão
12 outras pessoas executaram este guia.
F Fernandez
Membro desde: 01/13/15
435 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 3-4, Hickman Winter 2015 Membro de USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
Membros da 4
Autoria de 7 guias
6 comentários
What is the battery reference for replacement ?
skalpinou - Responder
which battery model do I purchase for replacing on an Acer Aspire R?
Eddie - Responder
hey how do you want då sel it for
Alex santos - Responder
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
Anthymoine - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 37
Duração total: 41,169
