Introdução
This guide shows the reader how to replace the RAM in their Acer Aspire R15.
Before starting this guide, it is important to ensure the device is unplugged and powered off in order to avoid doing serious damage to the electronics.
  1. Disconnect all power from the laptop and turn over so the bottom is facing you. Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Lift up the protective covering away from the RAM using tweezers, or your fingers.
    • Lift up the protective covering away from the RAM using tweezers, or your fingers.
  4. Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
 When released, the RAM module will pop up at a slight angle. Lift the RAM module to an angle of about 30 degrees and slide it out.
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
Conclusão
Uma outra pessoa concluiu este guia.
Kelly Johnston
433 reputação
4 Guides authored
Equipe
USF Tampa, Team S20-G2, Passmore Spring 2018 Membro de USF Tampa, Team S20-G2, Passmore Spring 2018
USFT-PASSMORE-S18S20G2
3 Membros
7 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Todo: 151
