Ir para o conteúdo principal
Acer Aspire R5-571T-59DC Hard Drive Replacement
O que você precisa
  1. Acer Aspire R5-571T-59DC Hard Drive Replacement, Back Cover Panel: passo 1, imagem 1 %32 Acer Aspire R5-571T-59DC Hard Drive Replacement, Back Cover Panel: passo 1, imagem 2 %32
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC Hard Drive Replacement, Battery: passo 2, imagem 1 %32 Acer Aspire R5-571T-59DC Hard Drive Replacement, Battery: passo 2, imagem 2 %32 Acer Aspire R5-571T-59DC Hard Drive Replacement, Battery: passo 2, imagem 3 %32
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
  3. Acer Aspire R5-571T-59DC Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Use a spudger to flip up the retaining flap on the hard drive ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  4. Acer Aspire R5-571T-59DC Hard Drive Replacement: passo 4, imagem 1 %32
    • Lift the hard drive up and out of the laptop.
Conclusão
7 outras pessoas executaram este guia.
Kelly Johnston
Membro desde: 01/25/18
600 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S20-G2, Passmore Spring 2018 Membro de USF Tampa, Team S20-G2, Passmore Spring 2018
USFT-PASSMORE-S18S20G2
Membros da 3
Autoria de 7 guias
Um comentário
I have bent the pins on my ZIF socket for my Aspire Laptop. Do you have the product name and number or know where I could buy a replacement part?
Samwise - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 4,496
