Ir para o conteúdo principal
Acer Aspire R5-571T-59DC Display Replacement
O que você precisa
  1. Acer Aspire R5-571T-59DC Display Replacement, Back Cover Panel: passo 1, imagem 1 %32 Acer Aspire R5-571T-59DC Display Replacement, Back Cover Panel: passo 1, imagem 2 %32
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
    What's the best way to safely remove and replace the bottom cover to prevent bending and otherwise stressing the casing and ports as you wiggle it loose and set it back in place?
    Alberto Einsteino - Responder
  2. Acer Aspire R5-571T-59DC Display Replacement, Battery: passo 2, imagem 1 %32 Acer Aspire R5-571T-59DC Display Replacement, Battery: passo 2, imagem 2 %32 Acer Aspire R5-571T-59DC Display Replacement, Battery: passo 2, imagem 3 %32
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
  3. Acer Aspire R5-571T-59DC Display Replacement, Display: passo 3, imagem 1 %32 Acer Aspire R5-571T-59DC Display Replacement, Display: passo 3, imagem 2 %32
    • Using a plastic opening tool, pry the back cover away from the screen.
  4. Acer Aspire R5-571T-59DC Display Replacement: passo 4, imagem 1 %32
    • Remove the tape covering the connector cables once the screen is separated from the display board.
  5. Acer Aspire R5-571T-59DC Display Replacement: passo 5, imagem 1 %32 Acer Aspire R5-571T-59DC Display Replacement: passo 5, imagem 2 %32
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Pull the ribbon cables out of the sockets.
Conclusão
Star Matthew
Membro desde: 01/25/18
155 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S20-G2, Passmore Spring 2018 Membro de USF Tampa, Team S20-G2, Passmore Spring 2018
USFT-PASSMORE-S18S20G2
Membros da 3
Autoria de 7 guias
Um comentário
I wish I found this tutorial before my fiance’ attempted to do this on his own. Now the replacement screen, albeit is not cracked, but the touch screen is pretty nonfunctional in my opinion. The corners don’t really work , sometimes it picks up my touch, sometimes it goes bonkers. The bottom corner of are bent and I’m continuously having to snap them back together. I’ve bought my laptop one year ago and I feel I already need to look into another. Any suggestions to try?? any help would be super appreciated.
Christina - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 2,022
