Ir para o conteúdo principal
Acer Aspire R5-571T-59DC Battery Replacement
O que você precisa
  1. Acer Aspire R5-571T-59DC Battery Replacement, Back Cover Panel: passo 1, imagem 1 %32 Acer Aspire R5-571T-59DC Battery Replacement, Back Cover Panel: passo 1, imagem 2 %32
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC Battery Replacement, Battery: passo 2, imagem 1 %32 Acer Aspire R5-571T-59DC Battery Replacement, Battery: passo 2, imagem 2 %32 Acer Aspire R5-571T-59DC Battery Replacement, Battery: passo 2, imagem 3 %32
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
Conclusão
Uma outra pessoa concluiu este guia.
Kelly Johnston
Membro desde: 01/25/18
600 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S20-G2, Passmore Spring 2018 Membro de USF Tampa, Team S20-G2, Passmore Spring 2018
USFT-PASSMORE-S18S20G2
3 Membros
Autoria de 7 guias
Um comentário
This seems to be the correct battery for the replacement, judging by the above photos, the AC14B3K
Acer AC14B3K, AC14B8J, and AC14B8K Laptop Battery
I plan to try this repair myself soon.
Sean Anderson - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 5,188
