Introdução
This is a in-speaker replacement guide for the Acer Aspire R5-471T-52EE. The following guide gives step by step instructions on how to remove and replace your in-device speakers. The in-device speakers are vital to the device’s sound functions, without these speakers the laptop will be unable to provide the user with any sound capabilities. While these are very important pieces of the device, they are not crucial to the device operation.
O que você precisa
Using your fingers, gently disconnect the battery plug from the motherboard.
Remove the two screws using a Phillips #00 screwdriver.
Remove the battery from the device.
Gently peel off all of the black take that sticks down the speaker cables.
Disconnect the two ribbon cables to allow the speaker cable to be removed from underneath.
Unplug the speaker cable from the motherboard.
Using a spudger, gently remove the speakers from the device.
Um comentário
I want to replace my laptop speakers but I am not getting them from anywhere, please send a purchase link also if you have the same speakers. email : prdp9101.com@gmail.com
