Ir para o conteúdo principal
Acer Aspire R5-471T-52EE Battery Replacement
O que você precisa
  1. Acer Aspire R5-471T-52EE Battery Replacement, Back Cover: passo 1, imagem 1 %32 Acer Aspire R5-471T-52EE Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Battery Replacement: passo 2, imagem 1 %32
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Battery Replacement, Battery: passo 3, imagem 1 %32
    • Using your fingers, gently disconnect the battery plug from the motherboard.
    • Remove the two screws using a Phillips #00 screwdriver.
    • Remove the battery from the device.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 1,107
