Ir para o conteúdo principal
Acer Aspire One ZG5 Wireless Card Replacement
O que você precisa
  1. Acer Aspire One ZG5 Wireless Card Replacement, Battery: passo 1, imagem 1 %32
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Wireless Card Replacement: passo 2, imagem 1 %32
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Wireless Card Replacement: passo 3, imagem 1 %32
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Wireless Card Replacement, Wireless Card: passo 4, imagem 1 %32
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Wireless Card Replacement: passo 5, imagem 1 %32
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Wireless Card Replacement: passo 6, imagem 1 %32
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Wireless Card Replacement: passo 7, imagem 1 %32
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Wireless Card Replacement: passo 8, imagem 1 %32
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
Conclusão
8 outras pessoas executaram este guia.
Doug Gallatin
Membro desde: 10/05/10
6.337 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 7-49, Amido Fall 2010 Membro de Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
Membros da 5
Autoria de 27 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 16
Duração total: 23,757
