Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this guide to replace or upgrade the RAM in the Acer Aspire One ZG5.
O que você precisa
Turn the netbook upside down with the battery at the top, facing away from you.
Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
Turn the netbook over and open the display so that the keyboard is facing you.
Close the display and turn the ZG5 over so that the battery compartment faces away from you.
Disconnect the two antenna cables from the right side of the wireless card.
63 outras pessoas executaram este guia.
23 comentários
Thanks a lot!!
It worked for me!
This guide lacks important information and technical accuracy.
The ZG5 can handle a maximum of 1.5GiB RAM, and realistically, can handle only an extra 512MiB RAM on top of the 512MiB fixed RAM, because of variations in the actual amount of RAM on the card you install.
I followed the entire guide, I have no more available RAM, and the tracker pad no longer works.
Thanks a bunch! I now have a netbook that is no longer a functioning netbook.
Please remove this guide until it addresses these important issues.
You are unfair to the author. This guide worked absolutely fine, and the guide has nothing to do with how much capacity your Acer Aspire One has, it has to do with how to exchange the RAM...
IF you want to fix things like highly compressed technology / like a mini laptop / yourself, you need to be sensitive. The way I have seen 9 out of 10 persons, they do not have that sensitivity. It is not a fault on you, and does not make you wrong. But you must be conscious about if you do not have the necessary sensitivity to do this work.
IFF your pad is not working, then try to do the same operation once more and be aware of how the mini laptop is to be handled at the various parts. I would guess that we are missing a wire in your laptop or something like that.
And - if you want it put in another way - since you couldn\t master doing it - then the money you saved on that RAM exchange - you can now spend them on fixing that small pad problem - with a professional.
I am blaming you for blaming the author.
facebook -
@Stone Forest - Come on, I followed this guide to upgrade my son's and my wife's friend's netbooks without problems at all. All you have to do is make sure you do the work on a static-free surface, wear your anti-shock/static wristband (do this ANY time you handle computer equipment!) and follow the steps. Voila!
I tried to install Kingston KVR667D2SO/2GB. the result is that doesn't work. did anybody try to install the 1GB?
