Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn the netbook upside down with the battery at the top, facing away from you.
Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
Slide the latch located on the opposite hinge from the lock while pushing the battery up.
Turn the netbook over and open the display so that the keyboard is facing you.
There are three tabs located on the top of the keyboard.
Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
As you move to the next tab, ensure the previous tab doesn't reset itself.
Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
12 outras pessoas executaram este guia.
