Ir para o conteúdo principal
Acer Aspire One ZG5 Keyboard Replacement
O que você precisa
  1. Acer Aspire One ZG5 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Keyboard Replacement: passo 2, imagem 1 %32
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Keyboard Replacement: passo 3, imagem 1 %32
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32
    • Turn the netbook over and open the display so that the keyboard is facing you.
  5. Acer Aspire One ZG5 Keyboard Replacement: passo 5, imagem 1 %32 Acer Aspire One ZG5 Keyboard Replacement: passo 5, imagem 2 %32 Acer Aspire One ZG5 Keyboard Replacement: passo 5, imagem 3 %32
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  6. Acer Aspire One ZG5 Keyboard Replacement: passo 6, imagem 1 %32 Acer Aspire One ZG5 Keyboard Replacement: passo 6, imagem 2 %32
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  7. Acer Aspire One ZG5 Keyboard Replacement: passo 7, imagem 1 %32 Acer Aspire One ZG5 Keyboard Replacement: passo 7, imagem 2 %32
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
Conclusão
12 outras pessoas executaram este guia.
Doug Gallatin
Membro desde: 10/05/10
6.337 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 7-49, Amido Fall 2010 Membro de Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
Membros da 5
Autoria de 27 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 24,656
