Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
After removing the top case, it is easy to get to the internal wireless card.
O que você precisa
Turn the netbook upside down with the battery at the top, facing away from you.
Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
Turn the netbook over and open the display so that the keyboard is facing you.
Close the display and turn the ZG5 over so that the battery compartment faces away from you.
Disconnect the two antenna cables from the right side of the wireless card.
5 outras pessoas executaram este guia.
