Introdução
The stick of RAM is either faulty or has come out of its slot and is causing issues with the computer. This guide will show you how to access the RAM on your computer.
Ferramentas
Peças
Nenhum componente especificado.
Put on an anti-static wrist band, attaching the end onto a large piece of metal.
Make sure the laptop is unplugged from its charging cord.
Flip the laptop over to view the underside.
Slide the right battery lock/unlock button to unlock, sliding the tab outward to unlock.
At the same time, slide the left tab outwards while placing thumb on the grip strips of the battery and pull the battery outwards until it slides out.
Flip the device over so bottom is exposed.
Remove the three screws at the front edge of the device using a Phillips #1 screwdriver.
Unscrew the screws holding the blue casing to the motherboard using a Phillips #1 screwbit:
Eleven 2mm Phillips #1 screws
Three 2mm Phillips #1 screws
Use the plastic opening tool on the left side of device to pop off blue casing and slide along the edge to loosen the casing.
Separate the blue casing from the rest of the device.
Remove the fourteen 2mm JIS #1 screws holding the motherboard to the device.
Carefully dissconnect any cables attached to the motherboard.
Remove the motherboard from the rest of the device.
5 outras pessoas concluíram este guia.
