Introdução
The keyboard on the Acer Aspire One D270-1865 will be easy to replace in just a few steps.
O que você precisa
Put on an anti-static wrist band, attaching the end onto a large piece of metal.
Make sure the laptop is unplugged from its charging cord.
Flip the laptop over to view the underside.
Slide the right battery lock/unlock button to unlock, sliding the tab outward to unlock.
At the same time, slide the left tab outwards while placing thumb on the grip strips of the battery and pull the battery outwards until it slides out.
Flip the device right-side up.
Open device.
Insert the plastic opening tool above the F8 key.
Gently pop off the keyboard by pulling up and towards you.
Uma outra pessoa concluiu este guia.
Um comentário
I need to replace the battery. It has served me well since 2012 - it's hard letting it go..which battery replacement is best..i have replaced the keyboard once, but not satisfying
