Ir para o conteúdo principal
Acer Aspire One D255E RAM Replacement
O que você precisa
  1. Acer Aspire One D255E RAM Replacement, Keyboard: passo 1, imagem 1 %32
    • Start by removing the battery found on the back of the device.
    • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
  2. Acer Aspire One D255E RAM Replacement: passo 2, imagem 1 %32 Acer Aspire One D255E RAM Replacement: passo 2, imagem 2 %32
    • Using plastic opening tools press down the 6 clips located around the keyboard.
  3. Acer Aspire One D255E RAM Replacement: passo 3, imagem 1 %32 Acer Aspire One D255E RAM Replacement: passo 3, imagem 2 %32 Acer Aspire One D255E RAM Replacement: passo 3, imagem 3 %32
    • Using a plastic opening tool or spudger move the keyboard out of position.
    • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
    • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E RAM Replacement: passo 4, imagem 1 %32
    • Using a spudger gently push the tab on the port forward then pull out the cable.
    • Be careful to do so as gently as possible. You do not want to damage the port.
  5. Acer Aspire One D255E RAM Replacement, Back Panel: passo 5, imagem 1 %32 Acer Aspire One D255E RAM Replacement, Back Panel: passo 5, imagem 2 %32
    • Unscrew seven 1.2 mm Phillips #1 screws from the back of the device
  6. Acer Aspire One D255E RAM Replacement: passo 6, imagem 1 %32 Acer Aspire One D255E RAM Replacement: passo 6, imagem 2 %32
    • Unscrew eight more 1.2 mm Phillips #1 screws from the front of the computer.
  7. Acer Aspire One D255E RAM Replacement: passo 7, imagem 1 %32 Acer Aspire One D255E RAM Replacement: passo 7, imagem 2 %32 Acer Aspire One D255E RAM Replacement: passo 7, imagem 3 %32
    • Using a spudger carefully push though the hole to dislodge the panel on the back of the device then remove the panel by hand.
    • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  8. Acer Aspire One D255E RAM Replacement, RAM: passo 8, imagem 1 %32 Acer Aspire One D255E RAM Replacement, RAM: passo 8, imagem 2 %32 Acer Aspire One D255E RAM Replacement, RAM: passo 8, imagem 3 %32
    • Using your hands pull apart the two clips holding the RAM in then pull out the RAM.
    • It uses (DDR3) 204pin PC3-10600 1333MHz DDR3 SO-DIMM Memory Modules
Conclusão
7 outras pessoas executaram este guia.
Brian
Membro desde: 03/19/16
1.248 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 Membro de UMass Dartmouth, Team 16-8, Bhusal Spring 2016
UMASSD-BHUSAL-S16S16G8
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 23
Duração total: 4,495
