Ir para o conteúdo principal
Acer Aspire One D250-1151 Battery Replacement
  1. Acer Aspire One D250-1151 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the computer is unplugged, and turned off completely
    • Place the computer on a flat surface with the bottom facing you.
  2. Acer Aspire One D250-1151 Battery Replacement: passo 2, imagem 1 %32
    • Place a finger on the small tab on the left with the lock and unlock symbols.
    • Slide this tab to the unlock position.
    • If done correctly, you should see an orange marker.
  3. Acer Aspire One D250-1151 Battery Replacement: passo 3, imagem 1 %32
    • Place a finger on the tab in the upper right corner.
    • Slide this tab to the right and hold it in that position.
  4. Acer Aspire One D250-1151 Battery Replacement: passo 4, imagem 1 %32
    • Place your finger on the three lines in the middle of the battery while holding the tab on the right.
  5. Acer Aspire One D250-1151 Battery Replacement: passo 5, imagem 1 %32
    • Push forward on the battery lines while holding the tab on the right.
Conclusão
Evan Edmunds
Membro desde: 10/31/16
237 Reputação
Autoria de 2 guias
Equipe
Baylor, Team 5-11, Williams Fall 2016 Membro de Baylor, Team 5-11, Williams Fall 2016
BU-WILLIAMS-F16S5G11
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 1,371
