Ir para o conteúdo principal
Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement
O que você precisa
  1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Back Panel: passo 1, imagem 1 %32 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the ten 7mm Phillips #0 screws from the bottom.
  2. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 2, imagem 1 %32 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 2, imagem 2 %32
    • Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
  3. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Battery: passo 3, imagem 1 %32 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Battery: passo 3, imagem 2 %32
    • Remove the two 5mm Phillips #0 screws from the battery.
  4. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 4, imagem 1 %32 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 4, imagem 2 %32 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 4, imagem 3 %32
    • Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
    • Remove the ribbon cables from the sockets.
  5. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 5, imagem 1 %32 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 5, imagem 2 %32 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 5, imagem 3 %32
    • Disconnect the battery from the motherboard.
    • Remove the battery.
  6. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Display: passo 6, imagem 1 %32 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Display: passo 6, imagem 2 %32
    • The battery is installed in these pictures but should always be removed before any part replacement.
    • Remove the four 5mm Phillips #0 screws from the display hinge.
  7. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 7, imagem 1 %32 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 7, imagem 2 %32
    • Disconnect the two antenna cables from the Wi-fi card.
  8. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 8, imagem 1 %32 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 8, imagem 2 %32
    • Disconnect the display cable by pulling it down and towards you.
  9. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 9, imagem 1 %32 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 9, imagem 2 %32
    • Lift the bottom half of the computer away from the screen while keeping the screen flat on the table surface.
    • This will allow the hinges holding the screen in place to lift up.
  10. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 10, imagem 1 %32
    • While the screen is flat on the surface, slide the bottom half of the computer towards the top of the screen to separate the two halves.
    • The screen is now completely removed from the bottom half of the computer.
Conclusão
Uma outra pessoa concluiu este guia.
Joseph
Membro desde: 01/25/18
685 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S20-G1, Passmore Spring 2018 Membro de USF Tampa, Team S20-G1, Passmore Spring 2018
USFT-PASSMORE-S18S20G1
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 1,664
