Ir para o conteúdo principal
Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement
O que você precisa
  1. Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement, Back Panel: passo 1, imagem 1 %32 Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement, Back Panel: passo 1, imagem 2 %32 Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement, Back Panel: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Power the laptop off.
    • Flip the laptop over and position it so the opening faces you.
    • Remove the rubber foot located near the opening side of the device using tweezers.
  2. Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement: passo 2, imagem 1 %32 Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement: passo 2, imagem 2 %32
    • Unscrew the five 5-mm screws using the PH0 screwdriver.
  3. Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement: passo 3, imagem 1 %32 Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement: passo 3, imagem 2 %32 Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement: passo 3, imagem 3 %32
    • Identify the HDMI port located in the side of the laptop opposite to the power button.
    • Insert the plastic opening tool into the divet of the back panel located above the HDMI port.
    • Pry along the laptop frame until the back panel comes loose.
    • Do not pull the back panel too hard as the battery is still connected to the back panel and the motherboard. This can damage your device.
  4. Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement: passo 4, imagem 1 %32 Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement: passo 4, imagem 2 %32
    • Rotate the device so the opening faces you again.
    • Hold the back panel away from the laptop and remove the 4-mm screw using the PH0 screwdriver.
    • This screw is fastening the battery to the laptop.
    • Lift the back panel gently.
  5. Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement: passo 5, imagem 1 %32 Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement: passo 5, imagem 2 %32
    • Unplug the cable that connects the battery to the motherboard.
    • Detach the back panel, which still includes the battery.
  6. Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement, WiFi Module: passo 6, imagem 1 %32 Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement, WiFi Module: passo 6, imagem 2 %32
    • Position the computer so the opening side faces you.
    • Remove the tape holding the WiFi module using tweezers.
  7. Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement: passo 7, imagem 1 %32
    • Unplug the white and black wires by lifting them up by hand or using tweezers.
  8. Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement: passo 8, imagem 1 %32
    • Remove the 3-mm screw that holds the WiFi module to the motherboard using the PH0 screwdriver.
  9. Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement: passo 9, imagem 1 %32 Acer Aspire One Cloudbook 11 AO1-131-C7DW WiFi Module Replacement: passo 9, imagem 2 %32
    • Pull the WiFi module out of the connector.
Conclusão
Uma outra pessoa concluiu este guia.
Luz Villegas
Membro desde: 09/08/17
452 Reputação
Autoria de 4 guias
Equipe
CSU Fullerton, Team S1-G4, Bruce Fall 2017 Membro de CSU Fullerton, Team S1-G4, Bruce Fall 2017
CSUF-BRUCE-F17S1G4
3 Membros
Autoria de 6 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 619
