Ir para o conteúdo principal
Acer Aspire One AO756-2623 LCD Sceen Replacement
O que você precisa
  1. Acer Aspire One AO756-2623 LCD Sceen Replacement, Battery: passo 1, imagem 1 %32
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 LCD Sceen Replacement: passo 2, imagem 1 %32
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 LCD Sceen Replacement: passo 3, imagem 1 %32 Acer Aspire One AO756-2623 LCD Sceen Replacement: passo 3, imagem 2 %32 Acer Aspire One AO756-2623 LCD Sceen Replacement: passo 3, imagem 3 %32
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Acer Aspire One AO756-2623 LCD Sceen Replacement, LCD Sceen: passo 4, imagem 1 %32
    • Orient the laptop as shown in the picture with the open screen facing toward you.
  5. Acer Aspire One AO756-2623 LCD Sceen Replacement: passo 5, imagem 1 %32 Acer Aspire One AO756-2623 LCD Sceen Replacement: passo 5, imagem 2 %32 Acer Aspire One AO756-2623 LCD Sceen Replacement: passo 5, imagem 3 %32
    • Insert the spudger into the indicated crease.
    • Firmly slide spudger around the edge of the entire laptop to remove the front plate of the screen.
    • Loud cracking noises from the plastic tabs separating may occur, do not worry, they are to be expected.
  6. Acer Aspire One AO756-2623 LCD Sceen Replacement: passo 6, imagem 1 %32 Acer Aspire One AO756-2623 LCD Sceen Replacement: passo 6, imagem 2 %32 Acer Aspire One AO756-2623 LCD Sceen Replacement: passo 6, imagem 3 %32
    • Identify the four 6 mm Phillips screws that are necessary to remove the LCD screen.
    • Remove all four screws using a Phillips #0 Screwdriver.
    • Pull away the LCD screen from the back cover of the laptop without ripping the ribbon cable connecting it to the bottom of the laptop.
  7. Acer Aspire One AO756-2623 LCD Sceen Replacement: passo 7, imagem 1 %32 Acer Aspire One AO756-2623 LCD Sceen Replacement: passo 7, imagem 2 %32 Acer Aspire One AO756-2623 LCD Sceen Replacement: passo 7, imagem 3 %32
    • Remove the tape covering the port connecting the screen to the bottom of the laptop.
    • To remove the LCD screen, gently pull the cable straight out of the screen.
    • In the first and second photos, the screen is lying face down on the keyboard.
Conclusão
3 outras pessoas executaram este guia.
Davis Adams
Membro desde: 03/20/16
465 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 7-1, Benson Spring 2016 Membro de Clemson, Team 7-1, Benson Spring 2016
CLEM-BENSON-S16S7G1
Membros da 4
Autoria de 14 guias
Um comentário
Spot on! Perfect tutorial thank-you very much!
Sonia Green - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 1,037
