Ir para o conteúdo principal
Acer Aspire One AO756-2623 Keyboard Replacement
O que você precisa
  1. Acer Aspire One AO756-2623 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 Keyboard Replacement: passo 2, imagem 1 %32
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 Keyboard Replacement: passo 3, imagem 1 %32 Acer Aspire One AO756-2623 Keyboard Replacement: passo 3, imagem 2 %32 Acer Aspire One AO756-2623 Keyboard Replacement: passo 3, imagem 3 %32
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Acer Aspire One AO756-2623 Keyboard Replacement, Back Cover: passo 4, imagem 1 %32
    • Locate the single 6 mm Phillips screw in the lower middle of the back plate.
    • Remove the screw using a Phillips #0 Screwdriver.
  5. Acer Aspire One AO756-2623 Keyboard Replacement: passo 5, imagem 1 %32 Acer Aspire One AO756-2623 Keyboard Replacement: passo 5, imagem 2 %32
    • Slide the back plate downward to remove it from the laptop.
  6. Acer Aspire One AO756-2623 Keyboard Replacement, Keyboard: passo 6, imagem 1 %32
    • Locate the eighteen 6 mm Phillips screws that are required to remove the keyboard.
    • Remove all screws using a Phillips #0 screwdriver.
  7. Acer Aspire One AO756-2623 Keyboard Replacement: passo 7, imagem 1 %32
    • Orient the laptop to where the open screen is facing towards you.
    • Slide the spuldger into the indicated crease.
    • Firmly slide spudger all the way around the laptop to pry the keyboard away from the bottom of the laptop.
    • Loud cracking noises will be heard during this step.
  8. Acer Aspire One AO756-2623 Keyboard Replacement: passo 8, imagem 1 %32 Acer Aspire One AO756-2623 Keyboard Replacement: passo 8, imagem 2 %32 Acer Aspire One AO756-2623 Keyboard Replacement: passo 8, imagem 3 %32
    • Remove the green dotted ribbon cable by sliding it straight out of the clamp holding it in using a plastic spudger.
    • Locate the two tabs that are holding the larger black ribbon cable in place.
    • Remove the larger black ribbon cable by pressing in the tabs and sliding it straight out of the clamp holding it in using a plastic spudger.
    • To remove the keyboard, lift the keyboard straight away from the rest of the laptop.
  9. Acer Aspire One AO756-2623 Keyboard Replacement: passo 9, imagem 1 %32 Acer Aspire One AO756-2623 Keyboard Replacement: passo 9, imagem 2 %32 Acer Aspire One AO756-2623 Keyboard Replacement: passo 9, imagem 3 %32
    • Locate the ten 6 mm Phillips screws that connect the keyboard to the rest of the laptop and remove them with a Phillips #0 Screwdriver.
    • Locate the four 6 mm Phillips screws hidden beneath black tape by lifting up the black tape and remove them with a Phillips #0 Screwdriver.
    • To remove keyboard from the rest of the laptop, pull keyboard straight up.
Conclusão
Uma outra pessoa concluiu este guia.
Davis Adams
Membro desde: 03/20/16
465 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 7-1, Benson Spring 2016 Membro de Clemson, Team 7-1, Benson Spring 2016
CLEM-BENSON-S16S7G1
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 19
Duração total: 1,493
