Ir para o conteúdo principal
Acer Aspire One AO756-2623 Back Cover Replacement
O que você precisa
  1. Acer Aspire One AO756-2623 Back Cover Replacement, Battery: passo 1, imagem 1 %32
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 Back Cover Replacement: passo 2, imagem 1 %32
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 Back Cover Replacement: passo 3, imagem 1 %32 Acer Aspire One AO756-2623 Back Cover Replacement: passo 3, imagem 2 %32 Acer Aspire One AO756-2623 Back Cover Replacement: passo 3, imagem 3 %32
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Acer Aspire One AO756-2623 Back Cover Replacement, Back Cover: passo 4, imagem 1 %32
    • Locate the single 6 mm Phillips screw in the lower middle of the back plate.
    • Remove the screw using a Phillips #0 Screwdriver.
  5. Acer Aspire One AO756-2623 Back Cover Replacement: passo 5, imagem 1 %32 Acer Aspire One AO756-2623 Back Cover Replacement: passo 5, imagem 2 %32
    • Slide the back plate downward to remove it from the laptop.
Conclusão
Colin Rodwell
Membro desde: 03/21/16
373 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 7-1, Benson Spring 2016 Membro de Clemson, Team 7-1, Benson Spring 2016
CLEM-BENSON-S16S7G1
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 1,725
