Ir para o conteúdo principal
Acer Aspire One A150-1672 Individual Key Replacement
O que você precisa
  1. Acer Aspire One A150-1672 Individual Key Replacement, Individual Key: passo 1, imagem 1 %32 Acer Aspire One A150-1672 Individual Key Replacement, Individual Key: passo 1, imagem 2 %32
    • To remove the keyboard, place the Blue Plastic Opening Tool at the 3 indentations above the keyboard as shown.
    • Slip the Blue Plastic Opening Tool in the space between the keyboard and the pink plastic casing and push down.
    • Pushing down on all 3 indentations should cause the keyboard to pop upwards slightly.
  2. Acer Aspire One A150-1672 Individual Key Replacement: passo 2, imagem 1 %32 Acer Aspire One A150-1672 Individual Key Replacement: passo 2, imagem 2 %32
    • There is a notch on the right side of the casing that blocks the keyboards ability to be removed.
    • Use the Blue Plastic opening tool and your fingers to pull up the top part of the keyboard as shown.
    • Use the Blue Plastic Opening Tool to separate the right side of the casing from the keyboard as shown.
    • After you have successfully moved the keyboard out from under the notch, pull the keyboard up.
  3. Acer Aspire One A150-1672 Individual Key Replacement: passo 3, imagem 1 %32
    • Using the Blue Plastic Opening Tool, pull up on the keyboard connector to completely detach the keyboard from the base of the laptop.
  4. Acer Aspire One A150-1672 Individual Key Replacement: passo 4, imagem 1 %32 Acer Aspire One A150-1672 Individual Key Replacement: passo 4, imagem 2 %32
    • Using the Blue Plastic Opening Tool, remove the white plastic piece of your desired key.
    • Place the Blue Plastic Opening Tool on the right side of the individual key, then gently pull up to detach the clips underneath.
    • Remove the key from the hinges by sliding the key to the left.
  5. Acer Aspire One A150-1672 Individual Key Replacement: passo 5, imagem 1 %32 Acer Aspire One A150-1672 Individual Key Replacement: passo 5, imagem 2 %32
    • Two ends need to be unhooked. They are located at the top and bottom of the key on the right side.
    • Using the Spudger, push the small, clear-colored end of the hinge out of the hook.
  6. Acer Aspire One A150-1672 Individual Key Replacement: passo 6, imagem 1 %32 Acer Aspire One A150-1672 Individual Key Replacement: passo 6, imagem 2 %32
    • Using the Blue Plastic Opening Tool, push the plastic hinge to the left to detach the hinge after the ends on the right are detached.
    • Remove the plastic hinge by pulling the plastic hinge upwards.
Conclusão
Vivianna
Membro desde: 10/30/16
101 Reputação
Autoria de 1 guia
Equipe
Baylor, Team 4-3, Williams Fall 2016 Membro de Baylor, Team 4-3, Williams Fall 2016
BU-WILLIAMS-F16S4G3
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 247
