Ir para o conteúdo principal
Acer Aspire One A150-1570 Keyboard Replacement
O que você precisa
  1. Acer Aspire One A150-1570 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Flip device over so that the battery is farthest from you.
    • Identify the switch on the upper left corner and push it left to be in "unlocked" position.
  2. Acer Aspire One A150-1570 Keyboard Replacement: passo 2, imagem 1 %32 Acer Aspire One A150-1570 Keyboard Replacement: passo 2, imagem 2 %32
    • Identify the latch on the upper right hand corner. Drag and hold the latch to the right.
    • Pull the battery out.
  3. Acer Aspire One A150-1570 Keyboard Replacement: passo 3, imagem 1 %32 Acer Aspire One A150-1570 Keyboard Replacement: passo 3, imagem 2 %32
    • Now flip device back over to show the keyboard.
    • Locate the three tabs at the top of the keyboard.
  4. Acer Aspire One A150-1570 Keyboard Replacement: passo 4, imagem 1 %32 Acer Aspire One A150-1570 Keyboard Replacement: passo 4, imagem 2 %32 Acer Aspire One A150-1570 Keyboard Replacement: passo 4, imagem 3 %32
    • Start on the top-right and use the spudger to push off the tab from the keyboard.
    • Move to the middle tab while still holding the right side up so the tab doesn't fall back into place.
    • Continue to hold up keyboard while disconnecting the last tab.
    • DO NOT lift keyboard yet. This will be addressed in the next step.
  5. Acer Aspire One A150-1570 Keyboard Replacement: passo 5, imagem 1 %32 Acer Aspire One A150-1570 Keyboard Replacement: passo 5, imagem 2 %32 Acer Aspire One A150-1570 Keyboard Replacement: passo 5, imagem 3 %32
    • Here you can see that the keyboard is still attached to the device.
    • Use the Spudger to lift the ZIF (Zero Insertion Force) to release the keyboard ribbon.
    • Once tab is lifted, the keyboard ribbon should come right out.
Conclusão
Blue
Membro desde: 10/10/16
124 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 403
