Ir para o conteúdo principal
Acer Aspire One 725-0845 Touchpad Replacement
O que você precisa
  1. Acer Aspire One 725-0845 Touchpad Replacement, Battery: passo 1, imagem 1 %32
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
  2. Acer Aspire One 725-0845 Touchpad Replacement: passo 2, imagem 1 %32 Acer Aspire One 725-0845 Touchpad Replacement: passo 2, imagem 2 %32 Acer Aspire One 725-0845 Touchpad Replacement: passo 2, imagem 3 %32
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
  3. Acer Aspire One 725-0845 Touchpad Replacement, Back Plate: passo 3, imagem 1 %32 Acer Aspire One 725-0845 Touchpad Replacement, Back Plate: passo 3, imagem 2 %32 Acer Aspire One 725-0845 Touchpad Replacement, Back Plate: passo 3, imagem 3 %32
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
  4. Acer Aspire One 725-0845 Touchpad Replacement, Hard Drive: passo 4, imagem 1 %32 Acer Aspire One 725-0845 Touchpad Replacement, Hard Drive: passo 4, imagem 2 %32
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (9.0 mm) from the outward side of the hard drive.
  5. Acer Aspire One 725-0845 Touchpad Replacement: passo 5, imagem 1 %32
    • Using your hand, slide the hard drive away from the center of the device until it disconnects from the motherboard.
    • Carefully lift the outward side of the hard drive and place the drive on a clean, non-magnetic surface.
  6. Acer Aspire One 725-0845 Touchpad Replacement, Inner Frame: passo 6, imagem 1 %32 Acer Aspire One 725-0845 Touchpad Replacement, Inner Frame: passo 6, imagem 2 %32 Acer Aspire One 725-0845 Touchpad Replacement, Inner Frame: passo 6, imagem 3 %32
    • Using the JIS J1 Screwdriver Bit and Driver, remove the six outside screws (7.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the seven inside screws (8.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the one inside screw (3.0 mm).
  7. Acer Aspire One 725-0845 Touchpad Replacement: passo 7, imagem 1 %32 Acer Aspire One 725-0845 Touchpad Replacement: passo 7, imagem 2 %32 Acer Aspire One 725-0845 Touchpad Replacement: passo 7, imagem 3 %32
    • Using your hands, slide the brown release tabs for the keyboard connection away from the center of the device.
    • Gently remove the keyboard connection by pulling away from the center of the device.
    • Lift the black locks for the touchpad connections into the upward position.
    • Gently remove the touchpad connections by pulling the purple tabs away from the locks.
  8. Acer Aspire One 725-0845 Touchpad Replacement: passo 8, imagem 1 %32 Acer Aspire One 725-0845 Touchpad Replacement: passo 8, imagem 2 %32 Acer Aspire One 725-0845 Touchpad Replacement: passo 8, imagem 3 %32
    • Flip the device over and open it.
    • Using the plastic opening tools, remove the cover/palm rest from the frame of the device.
  9. Acer Aspire One 725-0845 Touchpad Replacement, Keyboard: passo 9, imagem 1 %32 Acer Aspire One 725-0845 Touchpad Replacement, Keyboard: passo 9, imagem 2 %32
    • Using the JIS J1 Screwdriver Bit and Driver, remove the 17 screws (3.0 mm) from the back of the keyboard.
  10. Acer Aspire One 725-0845 Touchpad Replacement: passo 10, imagem 1 %32 Acer Aspire One 725-0845 Touchpad Replacement: passo 10, imagem 2 %32
    • Remove the keyboard by lifting up and away from the cover/palm rest. Be careful with the keyboard connection during this step.
    • To replace an individual key, remove the key from the keyboard using a plastic opening tool.
  11. Acer Aspire One 725-0845 Touchpad Replacement, Touchpad: passo 11, imagem 1 %32 Acer Aspire One 725-0845 Touchpad Replacement, Touchpad: passo 11, imagem 2 %32
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (7.0 mm) from touchpad buttons.
  12. Acer Aspire One 725-0845 Touchpad Replacement: passo 12, imagem 1 %32 Acer Aspire One 725-0845 Touchpad Replacement: passo 12, imagem 2 %32
    • On the cover/palm rest, lift the black locks for the touchpad buttons into the upward position.
    • Remove the connection for the touchpad buttons by gently pulling the purple tabs away from the locks.
    • Remove touchpad buttons by lifting them up and away from the cover/palm rest.
Conclusão
Joe Kendall
Membro desde: 02/15/17
346 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 8-3, Eyestone Spring 2017 Membro de USF Tampa, Team 8-3, Eyestone Spring 2017
USFT-EYESTONE-S17S8G3
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 21
Duração total: 1,392
