Ir para o conteúdo principal
Acer Aspire One 725-0845 RAM Replacement
O que você precisa
  1. Acer Aspire One 725-0845 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
  2. Acer Aspire One 725-0845 RAM Replacement: passo 2, imagem 1 %32 Acer Aspire One 725-0845 RAM Replacement: passo 2, imagem 2 %32 Acer Aspire One 725-0845 RAM Replacement: passo 2, imagem 3 %32
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
  3. Acer Aspire One 725-0845 RAM Replacement, Back Plate: passo 3, imagem 1 %32 Acer Aspire One 725-0845 RAM Replacement, Back Plate: passo 3, imagem 2 %32 Acer Aspire One 725-0845 RAM Replacement, Back Plate: passo 3, imagem 3 %32
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
  4. Acer Aspire One 725-0845 RAM Replacement, RAM: passo 4, imagem 1 %32 Acer Aspire One 725-0845 RAM Replacement, RAM: passo 4, imagem 2 %32 Acer Aspire One 725-0845 RAM Replacement, RAM: passo 4, imagem 3 %32
    • Using two fingers, push the clamps away from the RAM chip, releasing it from the motherboard.
    • Carefully remove the RAM chip by pulling it out and away from the center of the device.
Conclusão
John Allen
Membro desde: 02/15/17
134 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 8-3, Eyestone Spring 2017 Membro de USF Tampa, Team 8-3, Eyestone Spring 2017
USFT-EYESTONE-S17S8G3
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 512
