Ir para o conteúdo principal
Acer Aspire One 722 Screen Replacement
O que você precisa
  1. Acer Aspire One 722 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Screen Replacement: passo 2, imagem 1 %32
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Screen Replacement: passo 3, imagem 1 %32
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Screen Replacement: passo 4, imagem 1 %32 Acer Aspire One 722 Screen Replacement: passo 4, imagem 2 %32
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Screen Replacement: passo 5, imagem 1 %32
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
  6. Acer Aspire One 722 Screen Replacement, Screen: passo 6, imagem 1 %32 Acer Aspire One 722 Screen Replacement, Screen: passo 6, imagem 2 %32
    • Remove the black rubber clips from the bottom right and left of the netbook screen.
  7. Acer Aspire One 722 Screen Replacement: passo 7, imagem 1 %32 Acer Aspire One 722 Screen Replacement: passo 7, imagem 2 %32
    • Remove the screws under the black caps.
  8. Acer Aspire One 722 Screen Replacement: passo 8, imagem 1 %32 Acer Aspire One 722 Screen Replacement: passo 8, imagem 2 %32 Acer Aspire One 722 Screen Replacement: passo 8, imagem 3 %32
    • Slowly separate the screen casing from the screen.
    • Potential for device damage: Be careful when detaching the screen casing from the screen. If not done slowly, it can break.
  9. Acer Aspire One 722 Screen Replacement: passo 9, imagem 1 %32 Acer Aspire One 722 Screen Replacement: passo 9, imagem 2 %32 Acer Aspire One 722 Screen Replacement: passo 9, imagem 3 %32
    • Remove the screws located on the four corners of the screen.
  10. Acer Aspire One 722 Screen Replacement: passo 10, imagem 1 %32 Acer Aspire One 722 Screen Replacement: passo 10, imagem 2 %32 Acer Aspire One 722 Screen Replacement: passo 10, imagem 3 %32
    • Remove the two bottom screws.
    • Taking out these screws will allow you to remove the screen from its attachment.
  11. Acer Aspire One 722 Screen Replacement: passo 11, imagem 1 %32 Acer Aspire One 722 Screen Replacement: passo 11, imagem 2 %32 Acer Aspire One 722 Screen Replacement: passo 11, imagem 3 %32
    • On the bottom left of the screen there is a cord attached. Remove the tape that is attached to the screen.
  12. Acer Aspire One 722 Screen Replacement: passo 12, imagem 1 %32 Acer Aspire One 722 Screen Replacement: passo 12, imagem 2 %32 Acer Aspire One 722 Screen Replacement: passo 12, imagem 3 %32
    • On the green board, remove the two screws.
    • Remove the board.
Conclusão
4 outras pessoas executaram este guia.
Equipe
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 3,283
