Pular para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Shut the netbook off (Power down netbook at top left corner).
    • Shut the netbook off (Power down netbook at top left corner).
  2. Close the netbook and flip it over so that the back is facing up.
    • Close the netbook and flip it over so that the back is facing up.
  3. Slide the button below the battery to the right while simultaneously pulling the battery out.
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Remove the old battery and get the replacement battery. Remove the old battery and get the replacement battery.
    • Remove the old battery and get the replacement battery.
  5. PC Laptop Batteries
    Batteries for all the top PC brands, backed by our Quality Guarantee.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  6. Check the thin groves on the side of the battery entry and line the replacement battery up to that.
    • Check the thin groves on the side of the battery entry and line the replacement battery up to that.
  7. Remove the screw on the bottom of the netbook.
    • Remove the screw on the bottom of the netbook.
  8. Remove the backing plate.
    • Remove the backing plate.
  9. Unscrew the four screws that are holding the hard drive in place.
    • Unscrew the four screws that are holding the hard drive in place.
  10. Slowly lift the hard drive up and remove the sata cable that is connected to it. Slowly lift the hard drive up and remove the sata cable that is connected to it.
    • Slowly lift the hard drive up and remove the sata cable that is connected to it.
  11. Take your replacement hard drive and connect the sata cable to the hard drive. Take your replacement hard drive and connect the sata cable to the hard drive. Take your replacement hard drive and connect the sata cable to the hard drive.
    • Take your replacement hard drive and connect the sata cable to the hard drive.
Conclusão
4 outras pessoas concluíram este guia.
Christian Barboza
Membro desde: 25-10-2015
791 reputação
5 Guias de autoria
Equipe
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G6
3 Membros
5 Guias de autoria
لا يعمل بعد انسطاب عليه ماء ما الحل
Belql Sayes - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 53
Todo: 2,915
