Ir para o conteúdo principal
Acer Aspire One 722 Battery Replacement
  1. Acer Aspire One 722 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Battery Replacement: passo 2, imagem 1 %32
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Battery Replacement: passo 3, imagem 1 %32
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Battery Replacement: passo 4, imagem 1 %32 Acer Aspire One 722 Battery Replacement: passo 4, imagem 2 %32
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Battery Replacement: passo 5, imagem 1 %32
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
    Thanks-gr8 guide
    hotcatz - Responder
    Thanks for the easy to follow instructions and for the great pictures. That made everything easy.
    Siegfried Harrison Ph.D. - Responder
Conclusão
12 outras pessoas executaram este guia.
Equipe
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G6
Membros da 3
Autoria de 10 guias
4 comentários
First rate easy to understand completed in less than a minute.many thanks
Alan Fowler - Responder
I find myself computer savvy. These steps jarred my memory. They were perfect.
scolan910 - Responder
Thank you, you are a hero of 2021.
Athirah siagian - Responder
Thank you. Simple, yes, but a little encouragement always helps.
Wade Stanfill - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 65
Duração total: 12,309
