Ir para o conteúdo principal
Acer Aspire One 722 Battery Replacement
  1. Acer Aspire One 722 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Battery Replacement: passo 2, imagem 1 %32
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Battery Replacement: passo 3, imagem 1 %32
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Battery Replacement: passo 4, imagem 1 %32 Acer Aspire One 722 Battery Replacement: passo 4, imagem 2 %32
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Battery Replacement: passo 5, imagem 1 %32
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
Conclusão
12 outras pessoas executaram este guia.
Equipe
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G6
Membros da 3
Autoria de 10 guias
4 comentários
First rate easy to understand completed in less than a minute.many thanks
Alan Fowler - Responder
I find myself computer savvy. These steps jarred my memory. They were perfect.
scolan910 - Responder
Thank you, you are a hero of 2021.
Athirah siagian - Responder
Thank you. Simple, yes, but a little encouragement always helps.
Wade Stanfill - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 49
Duração total: 12,342
