Ir para o conteúdo principal
Acer Aspire One 532h-2806 Screen Replacement
O que você precisa
  1. Acer Aspire One 532h-2806 Screen Replacement, Screen: passo 1, imagem 1 %32 Acer Aspire One 532h-2806 Screen Replacement, Screen: passo 1, imagem 2 %32
    • Turn the device off before beginning any replacements.
    • Locate the two circular black stickers at the bottom corners of the laptop screen.
    • Remove the stickers.
    • Two 6mm Phillips Screws should now be visible.
  2. Acer Aspire One 532h-2806 Screen Replacement: passo 2, imagem 1 %32 Acer Aspire One 532h-2806 Screen Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 Screwdriver to remove the two 6mm screws from the screen.
  3. Acer Aspire One 532h-2806 Screen Replacement: passo 3, imagem 1 %32 Acer Aspire One 532h-2806 Screen Replacement: passo 3, imagem 2 %32
    • Using the opener tool, remove the plastic cover, surrounding the screen.
    • It is normal to hear clicking sounds as the plastic cover is removed.
  4. Acer Aspire One 532h-2806 Screen Replacement: passo 4, imagem 1 %32 Acer Aspire One 532h-2806 Screen Replacement: passo 4, imagem 2 %32 Acer Aspire One 532h-2806 Screen Replacement: passo 4, imagem 3 %32
    • Remove the four 6mm Phillips screws surrounding the screen.
    • These are holding the screen in place. After the screws are removed, the screen should remove itself from the plastic outer cover.
  5. Acer Aspire One 532h-2806 Screen Replacement: passo 5, imagem 1 %32
    • Peel back the fuss cable from the outer laptop plastic cover.
    • Be careful, not to yank or rip the cable, it should gently peel back.
  6. Acer Aspire One 532h-2806 Screen Replacement: passo 6, imagem 1 %32
    • Locate the ZIF (zero insertion force) Cable.
    • Peel back any tape if necessary
    • Carefully unplug it.
    • Do not pull hard, it should remove itself easily.
  7. Acer Aspire One 532h-2806 Screen Replacement: passo 7, imagem 1 %32 Acer Aspire One 532h-2806 Screen Replacement: passo 7, imagem 2 %32
    • Remove the two 6mm screws on each side of the screen with a Phillips #0 screwdriver.
  8. Acer Aspire One 532h-2806 Screen Replacement: passo 8, imagem 1 %32 Acer Aspire One 532h-2806 Screen Replacement: passo 8, imagem 2 %32 Acer Aspire One 532h-2806 Screen Replacement: passo 8, imagem 3 %32
    • Remove the screen.
Conclusão
Julie Paula
Membro desde: 01/12/17
527 Reputação
Autoria de 4 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 336
