Ir para o conteúdo principal
Acer Aspire One 532h-2806 Keyboard Replacement
O que você precisa
  1. Acer Aspire One 532h-2806 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Make sure the laptop is turned off and the battery is removed.
    • Above the top row of the keys, locate three plastic latches.
  2. Acer Aspire One 532h-2806 Keyboard Replacement: passo 2, imagem 1 %32
    • Use the medal spudger to press each tab. The keyboard should release.
    • Slide the spudger, so that the tabs do not reset after pressing each one.
  3. Acer Aspire One 532h-2806 Keyboard Replacement: passo 3, imagem 1 %32
    • Gently lift the keyboard up.
    • The keyboard ribbon cable is still attached to the motherboard.
  4. Acer Aspire One 532h-2806 Keyboard Replacement: passo 4, imagem 1 %32
    • Carefully unplug the connector sticker on the back of the keyboard.
    • Be gentle, do not force it out.
  5. Acer Aspire One 532h-2806 Keyboard Replacement: passo 5, imagem 1 %32
    • Remove the keyboard.
Conclusão
Julie Paula
Membro desde: 01/12/17
527 Reputação
Autoria de 4 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Ao todo: 407
