Ir para o conteúdo principal
Acer Aspire One 532h-2527 Hard Disk Drive Replacement
O que você precisa
  1. Acer Aspire One 532h-2527 Hard Disk Drive Replacement, Battery: passo 1, imagem 1 %32
    • Press the power button to turn off the netbook.
  2. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: passo 2, imagem 1 %32
    • Place the netbook bottom-side-up on a flat surface.
    • Locate the unlock latch on the top right corner of the back.
  3. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: passo 3, imagem 1 %32
    • To unlock the battery, slide the lock latch in the direction indicated by the unlocking icon. You should see the orange indicator which means that the latch is unlocked.
  4. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: passo 4, imagem 1 %32 Acer Aspire One 532h-2527 Hard Disk Drive Replacement: passo 4, imagem 2 %32 Acer Aspire One 532h-2527 Hard Disk Drive Replacement: passo 4, imagem 3 %32
    • On the opposite side, slide and hold the release latch.
    • Gently slide the battery out.
  5. Acer Aspire One 532h-2527 Hard Disk Drive Replacement, Back Plate: passo 5, imagem 1 %32
    • Use a #0 Phillips screwdriver to remove the three 6mm screws from the larger back plate.
  6. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: passo 6, imagem 1 %32
    • Use the plastic opening tool on the recessed notch at the bottom of the larger plate to gently lift the plate.
  7. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: passo 7, imagem 1 %32
    • Once the plate becomes unhinged, gently rotate the plate to take it off of the device.
  8. Acer Aspire One 532h-2527 Hard Disk Drive Replacement, Hard Disk Drive: passo 8, imagem 1 %32
    • Locate the HDD after the back plate is removed. It will be the large rectangle that takes up most of the space.
  9. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: passo 9, imagem 1 %32 Acer Aspire One 532h-2527 Hard Disk Drive Replacement: passo 9, imagem 2 %32
    • Gently press down on the HDD and slide it to the left as far as it will go.
  10. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: passo 10, imagem 1 %32 Acer Aspire One 532h-2527 Hard Disk Drive Replacement: passo 10, imagem 2 %32
    • Grab the edges of the HDD, slightly rotate it, and gently pull it out.
Conclusão
4 outras pessoas executaram este guia.
Erica Romero
Membro desde: 09/15/16
481 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 11-6, Blackwell Fall 2016 Membro de USF Tampa, Team 11-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G6
Membros da 3
Autoria de 12 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,652
