Ir para o conteúdo principal
Acer Aspire One 532h-2527 Screen Replacement
O que você precisa
  1. Acer Aspire One 532h-2527  Screen Replacement, Battery: passo 1, imagem 1 %32
    • Press the power button to turn off the netbook.
  2. Acer Aspire One 532h-2527  Screen Replacement: passo 2, imagem 1 %32
    • Place the netbook bottom-side-up on a flat surface.
    • Locate the unlock latch on the top right corner of the back.
  3. Acer Aspire One 532h-2527  Screen Replacement: passo 3, imagem 1 %32
    • To unlock the battery, slide the lock latch in the direction indicated by the unlocking icon. You should see the orange indicator which means that the latch is unlocked.
  4. Acer Aspire One 532h-2527  Screen Replacement: passo 4, imagem 1 %32 Acer Aspire One 532h-2527  Screen Replacement: passo 4, imagem 2 %32 Acer Aspire One 532h-2527  Screen Replacement: passo 4, imagem 3 %32
    • On the opposite side, slide and hold the release latch.
    • Gently slide the battery out.
  5. Acer Aspire One 532h-2527  Screen Replacement, Screen: passo 5, imagem 1 %32
    • Remove the two small circular stickers located on each side at the bottom of the screen.
    • Once stickers are removed, you should see a Phillips screw head underneath each sticker.
  6. Acer Aspire One 532h-2527  Screen Replacement: passo 6, imagem 1 %32 Acer Aspire One 532h-2527  Screen Replacement: passo 6, imagem 2 %32
    • Use the #0 Phillips Screw bit with the Screwdriver to remove the two 6mm Phillips screws from the bottom of the screen.
    • The screws are located where the stickers were in the previous step.
  7. Acer Aspire One 532h-2527  Screen Replacement: passo 7, imagem 1 %32 Acer Aspire One 532h-2527  Screen Replacement: passo 7, imagem 2 %32 Acer Aspire One 532h-2527  Screen Replacement: passo 7, imagem 3 %32
    • Using the plastic opening tool, gently separate the front plastic cover from the screen.
    • You should hear clicks as you go about removing the plastic cover.
  8. Acer Aspire One 532h-2527  Screen Replacement: passo 8, imagem 1 %32
    • Locate the four Phillips screws holding the screen in place.
    • Using the #0 Phillips Screw bit with the Screwdriver, remove the four 6mm Phillips screws around the screen.
  9. Acer Aspire One 532h-2527  Screen Replacement: passo 9, imagem 1 %32 Acer Aspire One 532h-2527  Screen Replacement: passo 9, imagem 2 %32
    • Using the plastic opening tool, gently lift the screen up from the back of the plastic laptop cover.
    • Use the plastic opening tool to remove the no fuss ribbon connector from the webcam component.
  10. Acer Aspire One 532h-2527  Screen Replacement: passo 10, imagem 1 %32 Acer Aspire One 532h-2527  Screen Replacement: passo 10, imagem 2 %32
    • Locate the no fuss ribbon connector wire.
    • Peel it from the backside of the screen.
  11. Acer Aspire One 532h-2527  Screen Replacement: passo 11, imagem 1 %32 Acer Aspire One 532h-2527  Screen Replacement: passo 11, imagem 2 %32
    • Locate the yellow tape on the back of the screen and peel it off partially.
    • Locate the ZIF (zero insertion force) connector cable.
    • Carefully unplug the ZIF connector.
    • No excess force is needed to remove the ZIF connector as its name implies.
    • Be sure to only pull the connector from its head and not the ribbon wire as it is very delicate.
  12. Acer Aspire One 532h-2527  Screen Replacement: passo 12, imagem 1 %32 Acer Aspire One 532h-2527  Screen Replacement: passo 12, imagem 2 %32
    • Locate the two 6mm screws on each side of the screen.
    • Use the #0 Phillips Screw bit with the Screwdriver to remove the four 6mm Phillips screws from each side of the screen.
  13. Acer Aspire One 532h-2527  Screen Replacement: passo 13, imagem 1 %32
    • Remove the screen.
Conclusão
Uma outra pessoa concluiu este guia.
Adam Debes
Membro desde: 09/15/16
153 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 11-6, Blackwell Fall 2016 Membro de USF Tampa, Team 11-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G6
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 688
