Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Place the laptop face down on a flat, clean surface.
Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
Be sure to evenly apply pressure when removing the back cover.
Remove the two 5 mm screws located on either side of the battery.
Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
Locate and remove the 5 mm screw using the Phillips #0 screwdriver.
Unscrew the four 5mm screws still holding down the fan.
Disconnect the red, white, black, and yellow bundled cable connectors from the motherboard by gently pulling them.
Remove the fan assembly.
Uma outra pessoa concluiu este guia.
