Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This replacement guide will teach the reader the proper way to remove the fan from their Acer Aspire ES1-711-P1UV. If the laptop is consistently getting too hot on the bottom or is making loud sounds that resemble that of a fan, the fan may need to be replaced. The fan serves to cool down the computer to prevent overheating. If the laptop gets too hot, it may shut down or damage the other mechanics.
O que você precisa
Place the laptop face down on a flat, clean surface.
Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
Locate and remove the 5 mm screw using the Phillips #0 screwdriver.
Unscrew the four 5mm screws still holding down the fan.
Uma outra pessoa concluiu este guia.
