Ir para o conteúdo principal
Acer Aspire ES1-711-P1UV Fan Replacement
O que você precisa
  1. Acer Aspire ES1-711-P1UV Fan Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Fan Replacement: passo 2, imagem 1 %32
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Fan Replacement: passo 3, imagem 1 %32
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Fan Replacement: passo 4, imagem 1 %32
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
  5. Acer Aspire ES1-711-P1UV Fan Replacement, Fan: passo 5, imagem 1 %32
    • Locate and remove the 5 mm screw using the Phillips #0 screwdriver.
    • Unscrew the four 5mm screws still holding down the fan.
    • The four 5mm screws in the second part of this step cannot be fully removed from the fan. Loosen them and continue on to Step 6.
  6. Acer Aspire ES1-711-P1UV Fan Replacement: passo 6, imagem 1 %32 Acer Aspire ES1-711-P1UV Fan Replacement: passo 6, imagem 2 %32 Acer Aspire ES1-711-P1UV Fan Replacement: passo 6, imagem 3 %32
    • Disconnect the red, white, black, and yellow bundled cable connectors from the motherboard by gently pulling them.
    • Remove the fan assembly.
Conclusão
Uma outra pessoa concluiu este guia.
Lindsay O'Shea
Membro desde: 03/22/18
414 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 624
