Ir para o conteúdo principal
Acer Aspire ES1-711-P1UV Battery Replacement
O que você precisa
  1. Acer Aspire ES1-711-P1UV Battery Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Battery Replacement: passo 2, imagem 1 %32
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Battery Replacement: passo 3, imagem 1 %32
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Battery Replacement: passo 4, imagem 1 %32
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
Conclusão
4 outras pessoas executaram este guia.
Lindsay O'Shea
Membro desde: 03/22/18
414 Reputação
Autoria de 3 guias
Equipe
2 comentários
Excellent instructions, Thxz.
jmarquez_cruz - Responder
Wuen i reassemble my laptop doesnt power on…
mk Bane - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 25
Duração total: 4,086
