Ir para o conteúdo principal
Acer Aspire ES1-512-C80E Battery Replacement
O que você precisa
  1. Acer Aspire ES1-512-C80E Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E Battery Replacement: passo 2, imagem 1 %32 Acer Aspire ES1-512-C80E Battery Replacement: passo 2, imagem 2 %32 Acer Aspire ES1-512-C80E Battery Replacement: passo 2, imagem 3 %32
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E Battery Replacement, Keyboard: passo 3, imagem 1 %32 Acer Aspire ES1-512-C80E Battery Replacement, Keyboard: passo 3, imagem 2 %32 Acer Aspire ES1-512-C80E Battery Replacement, Keyboard: passo 3, imagem 3 %32
    • The keyboard is the silver piece located by itself on the upper half of the laptop.
    • Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
    • Using a spudger, go around the edges and pry off the keyboard.
    • All black clips will have to be removed before the keyboard can be removed.
  4. Acer Aspire ES1-512-C80E Battery Replacement: passo 4, imagem 1 %32 Acer Aspire ES1-512-C80E Battery Replacement: passo 4, imagem 2 %32 Acer Aspire ES1-512-C80E Battery Replacement: passo 4, imagem 3 %32
    • Remove the ribbon cable connection from the keyboard.
    • Peel back the two pieces of tape to separate the keyboard.
    • Remove the keyboard from under the plastic covering.
    • Remove the silver plate back cover of the keyboard from the bottom base.
  5. Acer Aspire ES1-512-C80E Battery Replacement: passo 5, imagem 1 %32 Acer Aspire ES1-512-C80E Battery Replacement: passo 5, imagem 2 %32
    • Remove the large silver plate from the keyboard.
    • You can not remove the silver backing with the attached wire from the back of the keyboard.
  6. Acer Aspire ES1-512-C80E Battery Replacement: passo 6, imagem 1 %32
    • The keyboard is removed and ready to be replaced.
  7. Acer Aspire ES1-512-C80E Battery Replacement, Battery: passo 7, imagem 1 %32 Acer Aspire ES1-512-C80E Battery Replacement, Battery: passo 7, imagem 2 %32 Acer Aspire ES1-512-C80E Battery Replacement, Battery: passo 7, imagem 3 %32
    • Remove the two 1.2mm Phillips #00 screws securing the battery.
  8. Acer Aspire ES1-512-C80E Battery Replacement: passo 8, imagem 1 %32 Acer Aspire ES1-512-C80E Battery Replacement: passo 8, imagem 2 %32 Acer Aspire ES1-512-C80E Battery Replacement: passo 8, imagem 3 %32
    • Use a nylon spudger to remove the battery from the clips that hold it down.
  9. Acer Aspire ES1-512-C80E Battery Replacement: passo 9, imagem 1 %32 Acer Aspire ES1-512-C80E Battery Replacement: passo 9, imagem 2 %32 Acer Aspire ES1-512-C80E Battery Replacement: passo 9, imagem 3 %32
    • Remove the wired connection to the laptop by pulling the plug out of the motherboard.
    • Remove the battery from the laptop.
Conclusão
Robert Creighton
Membro desde: 10/31/19
682 Reputação
Autoria de 6 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 2,153
