Introdução
To replace the RAM is an in-depth procedure as it's located under the motherboard. There are a lot of screws from the various parts but they're all the same size so it doesn't matter where they go back in.
O que você precisa
Unscrew the 13 6.2mm screws located on the bottom of the laptop using the JIS #0 screwdriver.
Locate the small black button surrounded by a white circle near the battery on the motherboard.
Press and hold the button for five seconds.
Locate the hard drive and slide the hard drive to the left until it disconnects from the mother board.
Unscrew the one 6.2mm screw in the upper left-hand corner of the network card.
