Introdução
When removing the network card, be sure to note the positions of the black and white cables on the network card before removing them to ensure that you put them back in the correct space.
O que você precisa
Unscrew the 13 6.2mm screws located on the bottom of the laptop using the JIS #0 screwdriver.
Unscrew the one 6.2mm screw in the upper left-hand corner of the network card.
Quase terminado!
Conclusão
