Ir para o conteúdo principal
Acer Aspire ES1-111M-C7DE Network Card Replacement
O que você precisa
  1. Acer Aspire ES1-111M-C7DE Network Card Replacement, Back Cover: passo 1, imagem 1 %32 Acer Aspire ES1-111M-C7DE Network Card Replacement, Back Cover: passo 1, imagem 2 %32
    • Unscrew the 13 6.2mm screws located on the bottom of the laptop using the JIS #0 screwdriver.
  2. Acer Aspire ES1-111M-C7DE Network Card Replacement: passo 2, imagem 1 %32 Acer Aspire ES1-111M-C7DE Network Card Replacement: passo 2, imagem 2 %32 Acer Aspire ES1-111M-C7DE Network Card Replacement: passo 2, imagem 3 %32
    • Using a plastic opening tool, gently pry the lower case off. Place aside.
  3. Acer Aspire ES1-111M-C7DE Network Card Replacement, Network Card: passo 3, imagem 1 %32 Acer Aspire ES1-111M-C7DE Network Card Replacement, Network Card: passo 3, imagem 2 %32
    • You will see a white rectangular piece next to the upper left-hand corner of the motherboard that is connected with a black cord and a white cord; this is the network card.
    • Unscrew the one 6.2mm screw in the upper left-hand corner of the network card.
  4. Acer Aspire ES1-111M-C7DE Network Card Replacement: passo 4, imagem 1 %32 Acer Aspire ES1-111M-C7DE Network Card Replacement: passo 4, imagem 2 %32 Acer Aspire ES1-111M-C7DE Network Card Replacement: passo 4, imagem 3 %32
    • Remove the black and the white cords from the network card.
    • Slide the card out of the motherboard and replace it with the new one.
Conclusão
Payton Stewart
Membro desde: 09/25/17
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S3-G1, Cannon Fall 2017 Membro de USF Tampa, Team S3-G1, Cannon Fall 2017
USFT-CANNON-F17S3G1
4 Membros
Autoria de 6 guias
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 297
