Introdução
The hard drive is a relatively easy component to replace. That being said, you do have to be careful when removing it to not damage the connector.
O que você precisa
Unscrew the 13 6.2mm screws located on the bottom of the laptop using the JIS #0 screwdriver.
Locate the hard drive and slide the hard drive to the left until it disconnects from the mother board.
3 outras pessoas executaram este guia.
