Introdução
If your touch pad is not working and you have tried other troubleshooting options, it may need to be replaced. This guide will teach you how to replace the touch pad for this laptop. Be sure to fallow all of them steps in order. Make sure there is no AC power connected to the device before starting.
  1. Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
    • Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
  2. Using the plastic opening tool, lift up on the side opposite of the Ethernet connector.
    • Using the plastic opening tool, lift up on the side opposite of the Ethernet connector.
    • With the plastic opening tool under the bottom panel, work your way around the perimeter until the panel separates.
  3. Remove the two 6mm Phillips #0 screws from the battery.
    • Remove the two 6mm Phillips #0 screws from the battery.
  4. Disconnect the battery from the motherboard. Pull the battery up and out of the laptop.
    • Disconnect the battery from the motherboard.
    • Pull the battery up and out of the laptop.
  5. Remove the two 6mm Phillips #0 screws from the fan. Disconnect the fan from the motherboard.
    • Remove the two 6mm Phillips #0 screws from the fan.
    • Disconnect the fan from the motherboard.
    • Remove the four 6mm Phillips #0 screws from the heat sink.
    • Lift and remove the heatsink assembly from laptop.
  6. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  7. Remove the Wi-Fi card by pulling it from the motherboard socket.
    • Remove the Wi-Fi card by pulling it from the motherboard socket.
  8. Disconnect the display cable from the motherboard.
    • Disconnect the display cable from the motherboard.
  9. Disconnect the speaker from the motherboard.
    • Disconnect the speaker from the motherboard.
  10. Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets. Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
    • Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
  11. Use a spudger to flip up the retaining flap on the black ribbon cable ZIF socket. Use a spudger to flip up the retaining flap on the black ribbon cable ZIF socket.
    • Use a spudger to flip up the retaining flap on the black ribbon cable ZIF socket.
  12. Lift the motherboard up from the narrow side and jiggle slightly so that way it doesn't get caught on the ports of the laptop case.
    • Lift the motherboard up from the narrow side and jiggle slightly so that way it doesn't get caught on the ports of the laptop case.
  13. Peel the black adhesive film up.
    • Peel the black adhesive film up.
  14. Remove the three 6mm Phillips #0 screws from touchpad.
    • Remove the three 6mm Phillips #0 screws from touchpad.
  15. Use a spudger to flip up the retaining flap on the touchpad ribbon cable ZIF socket.
    • Use a spudger to flip up the retaining flap on the touchpad ribbon cable ZIF socket.
    • Remove the ribbon cable from the ZIF socket.
  16. Lift the touchpad up by the side closest to the middle of the laptop and pull up towards you to remove. Lift the touchpad up by the side closest to the middle of the laptop and pull up towards you to remove.
    • Lift the touchpad up by the side closest to the middle of the laptop and pull up towards you to remove.
Conclusão
Ed Herrera
217 reputação
2 Guides authored
Equipe
USF Tampa, Team S7-G3, Passmore Spring 2018 Membro de USF Tampa, Team S7-G3, Passmore Spring 2018
USFT-PASSMORE-S18S7G3
4 Membros
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Todo: 58
