Ir para o conteúdo principal
Acer Aspire E5-721-64T8 Motherboard Replacement
O que você precisa
  1. Acer Aspire E5-721-64T8 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Remove the two 6mm J0 screws located in the right and left side of the battery.
    • Make sure to unplug of disconnect the power cable before removing the battery.
  2. Acer Aspire E5-721-64T8 Motherboard Replacement: passo 2, imagem 1 %32 Acer Aspire E5-721-64T8 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the connector from the motherboard.
  3. Acer Aspire E5-721-64T8 Motherboard Replacement: passo 3, imagem 1 %32 Acer Aspire E5-721-64T8 Motherboard Replacement: passo 3, imagem 2 %32 Acer Aspire E5-721-64T8 Motherboard Replacement: passo 3, imagem 3 %32
    • Remove the two 6mm Phillips J0 screws located in the right and left side of heatsink mounts.
    • Remove the four 6mm Phillips J0 screws located on the heatsink power mount.
    • Lift and remove heatsink from motherboard completely.
  4. Acer Aspire E5-721-64T8 Motherboard Replacement: passo 4, imagem 1 %32 Acer Aspire E5-721-64T8 Motherboard Replacement: passo 4, imagem 2 %32
    • Remove wi-fi card by pulling from socket.
  5. Acer Aspire E5-721-64T8 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove screen connector by pulling it upwards.
  6. Acer Aspire E5-721-64T8 Motherboard Replacement: passo 6, imagem 1 %32
    • Remove speaker connector from the motherboard by pulling on the tab.
  7. Acer Aspire E5-721-64T8 Motherboard Replacement: passo 7, imagem 1 %32 Acer Aspire E5-721-64T8 Motherboard Replacement: passo 7, imagem 2 %32 Acer Aspire E5-721-64T8 Motherboard Replacement: passo 7, imagem 3 %32
    • Remove the four blue tabbed ribbon connectors to the motherboard by lifting white clamps and pulling out connector.
  8. Acer Aspire E5-721-64T8 Motherboard Replacement: passo 8, imagem 1 %32 Acer Aspire E5-721-64T8 Motherboard Replacement: passo 8, imagem 2 %32
    • Remove black ribbon connector by lifting white clamp and pulling connector out.
  9. Acer Aspire E5-721-64T8 Motherboard Replacement: passo 9, imagem 1 %32 Acer Aspire E5-721-64T8 Motherboard Replacement: passo 9, imagem 2 %32
    • Finally lift motherboard from narrow side and jiggle it out so all ports going through the laptop case on the left slide out.
Conclusão
Ed Herrera
Membro desde: 01/25/18
390 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S7-G3, Passmore Spring 2018 Membro de USF Tampa, Team S7-G3, Passmore Spring 2018
USFT-PASSMORE-S18S7G3
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 191
