Ir para o conteúdo principal
Acer Aspire E5-573G Battery Replacement
O que você precisa
  1. Acer Aspire E5-573G Battery Replacement, Optical Drive: passo 1, imagem 1 %32
    • Ensure your device is OFF before beginning this procedure.
    • Unscrew the 5 mm Phillips head screw holding the drive in place.
  2. Acer Aspire E5-573G Battery Replacement: passo 2, imagem 1 %32
    • Pull out the disk drive.
  3. Acer Aspire E5-573G Battery Replacement, Battery: passo 3, imagem 1 %32
    • Unscrew the seventeen 5 mm Phillips head screws from the bottom cover.
  4. Acer Aspire E5-573G Battery Replacement: passo 4, imagem 1 %32
    • Unscrew the three 2.5 mm Phillips head screws underneath the optical drive bay.
  5. Acer Aspire E5-573G Battery Replacement: passo 5, imagem 1 %32
    • Run a pick between the bottom cover and the device around the edge of the laptop and unclip the cover from the rest of the device.
  6. Acer Aspire E5-573G Battery Replacement: passo 6, imagem 1 %32
    • Lift the left side of the bottom cover, but do not completely remove the cover, as the speaker is cable is still connected and will be damaged.
    • Pull the speaker connector towards the fan to disconnect it from its socket on the motherboard.
  7. Acer Aspire E5-573G Battery Replacement: passo 7, imagem 1 %32
    • Pull the battery connector towards the battery to disconnect it from its socket on the motherboard.
    • Remove the battery.
Conclusão
14 outras pessoas executaram este guia.
Alex Bahm
Membro desde: 01/18/18
2.226 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S12-G5, Banghart Winter 2018 Membro de Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
Membros da 2
Autoria de 15 guias
Um comentário
Where can i buy a battery replacement for my aspire e5-573g-59c3?
mfortich98 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 69
Duração total: 21,625
