Ir para o conteúdo principal
Acer Aspire E5-571-58CG Touchpad Replacement
O que você precisa
  1. Acer Aspire E5-571-58CG Touchpad Replacement, Keyboard: passo 1, imagem 1 %32 Acer Aspire E5-571-58CG Touchpad Replacement, Keyboard: passo 1, imagem 2 %32 Acer Aspire E5-571-58CG Touchpad Replacement, Keyboard: passo 1, imagem 3 %32
    • Make sure laptop is upright.
    • Pry the keyboard cover off with the plastic opening tool.
  2. Acer Aspire E5-571-58CG Touchpad Replacement: passo 2, imagem 1 %32 Acer Aspire E5-571-58CG Touchpad Replacement: passo 2, imagem 2 %32 Acer Aspire E5-571-58CG Touchpad Replacement: passo 2, imagem 3 %32
    • Flip the keyboard cover upside down.
    • Use the JIS #000 screw bit to remove the marked M1.4 x 2 mm screws from the back of the metal panel.
  3. Acer Aspire E5-571-58CG Touchpad Replacement: passo 3, imagem 1 %32 Acer Aspire E5-571-58CG Touchpad Replacement: passo 3, imagem 2 %32 Acer Aspire E5-571-58CG Touchpad Replacement: passo 3, imagem 3 %32
    • Push the metal panel forward to unlock it from plastic holders on both sides.
    • Lift the metal panel up and peel it back to expose the keyboard component.
  4. Acer Aspire E5-571-58CG Touchpad Replacement: passo 4, imagem 1 %32 Acer Aspire E5-571-58CG Touchpad Replacement: passo 4, imagem 2 %32 Acer Aspire E5-571-58CG Touchpad Replacement: passo 4, imagem 3 %32
    • Use the metal spudger to lift the keyboard component out of the metal panel.
  5. Acer Aspire E5-571-58CG Touchpad Replacement, Touchpad: passo 5, imagem 1 %32 Acer Aspire E5-571-58CG Touchpad Replacement, Touchpad: passo 5, imagem 2 %32
    • Make sure you have removed the keyboard before attempting to remove the touchpad.
    • Use a 1 1/2 mm flathead screw bit to remove the black screw at the bottom of the panel.
  6. Acer Aspire E5-571-58CG Touchpad Replacement: passo 6, imagem 1 %32 Acer Aspire E5-571-58CG Touchpad Replacement: passo 6, imagem 2 %32 Acer Aspire E5-571-58CG Touchpad Replacement: passo 6, imagem 3 %32
    • Peel back the marked strips with the metal spudger.
  7. Acer Aspire E5-571-58CG Touchpad Replacement: passo 7, imagem 1 %32 Acer Aspire E5-571-58CG Touchpad Replacement: passo 7, imagem 2 %32 Acer Aspire E5-571-58CG Touchpad Replacement: passo 7, imagem 3 %32
    • Use a 1 1/2 mm flathead screw bit to remove the two black screws at the top of the panel.
  8. Acer Aspire E5-571-58CG Touchpad Replacement: passo 8, imagem 1 %32 Acer Aspire E5-571-58CG Touchpad Replacement: passo 8, imagem 2 %32
    • Lift the touch pad out of the metal panel with a metal spudger.
Conclusão
Daniel Mello
Membro desde: 10/16/18
258 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 Membro de UMass Dartmouth, Team S7-G7, Valliere Fall 2018
UMASSD-VALLIERE-F18S7G7
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 14
Duração total: 1,241
